M35 '06 vs '08 Backup camera
TDot
Car: 2008 M35X, Lakeshore Slate/Tan
Does anyone know if the backup camera from '06 M35 is the same quality and resolution as the '08?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
I just checked InfinitiPartsDeal
Camera Assy-Back View
M35 2006
Vehicle Production Date: 12/2004-05/2005
Part #28442-EG000
Replaced By: #28442-EG01A
M35 2006
Vehicle Production Date: 05/2005-11/2005
Part #28442-EG00A
M35 2006-2008
Vehicle Production Date: 11/2005-09/2007
Part #28442-EG01A
TDot
Thanks, I know it will work...eg01a...but I wanted to know if it had the same image quality as the 08 version...ej70a. Hopefully someone may have driven both years, or replaced the 08 with the 06 and could speak on it. Trying to save a couple dollars where I can with the amount of money I'm about to sink in this car.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
When it says "replaced by" it means it's a direct supersession, usually because Nissan changed vendors and not because the part is different. If your '08 has a different part number not included in that chain, the two cameras may not even work if swapped.
TDot
Thanks both. Apparently my manufacture date, I have to go with the model number that came out. So looks like I'm spending the money.
