isnt this only for cars with XM (SAT) option? i dont have SAT on my car?Brian35XR wrote:bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi bt45-infi
IlyaKol wrote:Welcome to the forum.
I got AUX via the USA Spec PA15-NIS unit...if your radio had XM you'll need the PA15-INFI unit.
I have also heard that USA Spec put out some sort of bluetooth module. Other members can chime in there...
The bt45 plugs into the sat receiver and that's it..kmiles wrote:I installed the PA15-INFI about 3 years ago and upgraded it to the BT45 about 45 days ago. The PA15-INFI was connected to my satellite, and i just unplugged the PA15-INFI from the cable to the satellite and it worked immediately once I connected with bluetooth. The BT45 comes with a cable that connects to the radio, and I understand it will work with that connection whether you have satellite or not. Personally - neither unit has proved to be 100% perfect and they have different pros and cons. Audio quality is great on the BT45 and it seems to connect fairly fast when you start up the car. If you're interested in my list of pros and cons on either unit, please let me know.
So since i don't have SAT receiver i would not be able to use the bt45? so i would have to use the pa15?Brian35XR wrote:The bt45 plugs into the sat receiver and that's it..kmiles wrote:I installed the PA15-INFI about 3 years ago and upgraded it to the BT45 about 45 days ago. The PA15-INFI was connected to my satellite, and i just unplugged the PA15-INFI from the cable to the satellite and it worked immediately once I connected with bluetooth. The BT45 comes with a cable that connects to the radio, and I understand it will work with that connection whether you have satellite or not. Personally - neither unit has proved to be 100% perfect and they have different pros and cons. Audio quality is great on the BT45 and it seems to connect fairly fast when you start up the car. If you're interested in my list of pros and cons on either unit, please let me know.
