TheXev »
https://forums.nicoclub.com/thexev-u70483.html
Tue Jul 10, 2007 12:26 pm
Okay, so I bought this M30 at the end of January this year, and it has suffered from constant overheating issues. First, i had to replace the top hose from the motor to the radiator with a brand new hose, then I had to rig the bleeder valve to stop leaking with a screw (i do plan to replace this). Next, the top end cap on the radiator cracked, and I had to replace that. Then, to try and reduce the amount of heat in the system, we installed a external transmission cooler out of a Ford Explorer to cool the transmission. It appeared to stop the car from heating up... as fast.
The system is still boiling if the car is driven for prolonged lengths of time!!!?
We've checked every part of the system. Does anyone have any ideas or similar experiences? The only other thing I feel left to swap would be the thermostat...
