M30 w/ 20K miles
EM-30
Car: cave diver
I have had this '91 M since new. I have 3 problems.
Intermittent no crank. I hold the key all the way to start and after holding it there for 2-3 seconds it will crank at normal speed and start. It has done that every 2 years. It seems to go away after I replace the batt. Even though the old one checks good. With the old batt and headlights on I get no yellow during cranking. I read about a blue relay on driverside engine compartment in a Maxima. So it seems the starter/ign switch/relay likes to see lots of current. Some of the positive batt wires are looking a little rusty but I don't think it is the problem.
Factory temp gauge in dash shows higher than normal only in the summer w/ AC on. I will drain and flush burp the air out and see if that fixes it. I have drained and flushed it only 3 times, the last one being 2 years ago. Did not use distiled water or water wetter and used a 50/50 mix. Do the clutchfans fail at 20K mi?
The power antenna sticks. I disconnected the bluewire to the motor. FM is OK but AM sucs. It gets the FM from the winshield ant. I am too old and fat to fit into that trunk and tear out the driverside wall.
I have drained and refilled the trans 4 times. No flush and no pan drop. I used dexron II per manual. Should I use Mobil 1 on this transmission? with a flush and then a pandrop 2 weeks later? Should I bypass the rad cooler or just add a ATF cooler in series? I can't fit a big one in front of the rad as the passenger side of the rad has a e.fan in front. So I am leaning towards a series setup with a small cooler providing I have good flow thru the rad oil lines. Does that transmission have a filter or a screen? I did not see a filter or screen in the mini manual. I think I read all the posts. I don't see too many M's
NOT my mamas car but it IS my Ole Ladys car. lol ;)
Q45tech
OLD cars cannot rely on low mileage because age is the factor unless you changed oil every 90 days [assumming you drive or had the engine running 65 hours in those days].
Same with other fluids they may absorb water vapor and turn acidic from just sitting there!Low annual mileage means everything else still gets changed every 2 years.Rubber hoses, seals, and suspensions harden from ambient heat and ozone exposure.
My son purchased a 1989 turbo Firebird from a museum with 500 miles it was only 7 years old..........every rubber part had to be replaced [$3800].
A 13-14 year old 20k car can be just rotten [hoses, suspension, and harnesses].
EM-30
Car: cave diver
Once every two or 3 weeks I take it out for a 10 mile ride to cook the oil. During the last 3 miles a few WOT's. I go real easy on it cold. I usually let it idle until the t stat starts to open. I think it likes sitting in the garage. (full shade) The paint and interior look new. I do not change oil every 90 days. I use Mobile 1 and replace the oil & filter every 6 months. Usually has about 1Kmiles.
It has original belts and hoses. (except for the upper rad) I have rotted 2 sets of tires. Brake and PS fluid is orig. Looks like I am going to have to spend some $$ on it if I am going to keep it. Sonar suspension still works. I went to a Nissan dealer to buy belts and hoses they said I needed to go to Infinity. I guess I have been lucky so far No brake, engine or transmission problems......yet.
I will turkey baster my PS fluid, flush brake lines and add a ATF cooler. My highest priority is coolant flush. The rad petcok won't open so I will pull the lower hose to drain. Better get a new hose b4 I do that.
Any other recommendations for my '91 M? I took it in for the fuel recall.
PalmerWMD
Car: 2004 350Z
EM30:
welcome to our little club.Real interesting car you have there!Please take some pictures and post them to our members ride section ( link is in my sig on bottom of this post).
Looks like you are doing what you need for the upkeep on an early Infiniti-- a piece of our marques history.
Fred...:)
91M30
EM-30 wrote:I have had this '91 M since new. I have drained and refilled the trans 4 times. No flush and no pan drop. I used dexron II per manual.
Hi, EM-30,
My wife's 1991 M30 with about 60K miles has a rather harsh 1-2 shift when cold, and is slow to do a 2-3 shift or to lock up into overdrive when warm; i.e., if throttle is held steady to hold RPM at 3000, it will not shift unless you back off very slightly on the throttle. Just curious.....does your M30 have similar shifting characteristics?
EM-30
Car: cave diver
Hi 91M30,
So far I have not ever had any shifting problems. Each time I drained the hot oil over a 2 day period. It was still dripping. I am still looking for a answer to my question of: Should I use Mobile 1 ATF on this trans? I want to do another drain and add a small cooler in series with the rad cooler and flush coolant to reduce seal damage.
Did you ever have any of my symptoms listed above?
91M30
EM-30 wrote:Hi 91M30, Did you ever have any of my symptoms listed above?
No......only problem has been the shifting symptoms described above.
