M30 Trans seems like it is starting in 2nd?
prts4days
Car: 1990 M30
I have a 1990 m30 that sat for little while but drove and shifted fine before it sat now it doesn't shift quite right. I can manually shift it to first and then it seems better but if I just put in gear and go it feels like something is hanging up or holding it back. Any ideas? Also is this transmission a basic rebuild or is there any tricks to the assembly? Thanks
chitownq45
Car: Q45
Can you let me know if you found out the problem.....I'm having the same problem...seems like when the car is cold the trans shifts fine....but once the car warms up I have the shifting problems as you do and also it seems as if my overdrive doesnt engage either. you can note me here or email me at [email protected]
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
It seems as if maybe its in fail-safe. When taht happens it locks in 3rd gear.. I dont have an M30 service manual so I cant give you any procedure how to check the AT codes... Maybe someone else will chime in.
