Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Tue Oct 12, 2004 6:49 pm
If the M is anything like the Q of that era, your guess about bad amps is probably correct. You can have them rebuilt, or go with an all new aftermarket system.
Rebuilds cost between $50-75 per amp. Of course it could be a head unit (radio) issue. You might move the one good speaker to the left spot and see if the good sound follows it... You can probably plug it in to the other spots to check them as well.
Heath
