dirtym30 »
https://forums.nicoclub.com/dirtym30-u240447.html
Mon Aug 25, 2014 4:23 pm
Whats up man, I literally just got done doing all of this earlier today.
Good news is ur speakers are probably good, bad news is its annoying to bypass the amps.
For the rears the amps are attached to the bottom of the speaker. Remove the 4 screws holding it to the back cover and unplug it.
Unscrew the bottom plastic cover (4 screws with 1/4 heads). Now what I did was cut the purpe and yellow wires coming from the speaker side of the plug. I then ran them directly to the speaker itself. Its the same on both sides.
The fronts are annoying but you end up doing the same process, even same color wires.
Remove the door panels, then the big a** speaker boxes. Once again you need to remove the 1/4 hex screws and there are about 14 per side. Same thing, just go directly to the speakers and you should be fine.
** just remember to unplug the white connector to each amp and leave it disconnected
