JPS48 »
https://forums.nicoclub.com/jps48-u151832.html
Sat Sep 01, 2012 2:37 pm
Frank,
Thanks for the update. Funny what creatures of habit we humans are. You talk about how it is you use the handbrake without even thinking about it whereas I've never or rarely have had to use one. In fact with a previous vehicle we owned, a 2000 Toyota 4Runner I don't think we had ever used it such that in it's 7th or 8th year, I discovered after using it, they wouldn't release. Luckily it was easy to fix.
As for the revs, I agree completly but have found that many small 4cyl engines these days are actually designed to rev at fairly high rpm's at highway speeds. When the New Beetle first hit the market I came very close to buying a gas version until I noticed that at 65 to 70 mph, the tach was well over 3000 rpm (not unlike the Versa). For that reason I ended up buying the turbo diesel version which reved almost a 1000 rpm less at highway speeds. I only wish more manufacturers who offer very appealing diesels in other markets would bring them to North America. As you probably know diesels outnumber gas engines in most of the world and many manufacturers even offer more than a single diesel choice depending upon the model. I'm still convinced GM is to blame for the NA anti diesel mindset ever since their failed attempt with Oldsmobile back in the late 70's. Anyway. . . .
With respect to your mileage, can I assume your referring to U.S. gallons? If so, your numbers are pretty good compared to mine. I get between 33 and 35 (mostly city) on an imperial gallon which is 1/5th larger than a U.S. gallon. Perhaps that will improve with more miles, I'm not sure, but we continue to use our 17 year old Civic for longer trips since no matter how hard you drive it it never drops below 45mpg and often surpasses 50!
