bicsintegra »
https://forums.nicoclub.com/bicsintegra-u130724.html
Mon Dec 03, 2018 7:14 pm
so I went to drive my 06 M which has not moved in about 6 weeks except from one side of the driveway to the other, and I noticed smoke coming from the hood. after I checked under the hood it appears it is coming from the rear left side of the engine(passenger) and it only happens after about 10 minutes of the car running. the car does not overheat or the temp gauge does not go above the normal mark, it also smells like something plastic is burning. about 3 months ago I had the radiator, thermostat, cooling fans and shroud replaced at the dealership. I also added a Injen CAI also. But the car has maybe 50 miles on it in the last 2 months or so, so I was thinking maybe a hose had rotted out or cracked since it sits dormant for so long. Any suggestions? Thanks in advance.
