M45Caliber »
https://forums.nicoclub.com/m45caliber-u98401.html
Thu Jun 05, 2008 1:01 pm
only two things I can think of (since you mentioned you checked air pressures)1. a caliper is binding - applying MORE pressure (your right front caliper) than the other 3 calipers -- when you get out of the car after driving it, see if the right front WHEEL is hotter than the others (careful not to burn your fingers...)2. Radial tire belt separation might affect this as well; the tire might flex more due to a belt separation, although this is more far-fetched.
My guess, due to the extremely low miles for an '04, is the caliper. With so little use it's quite possible to get some pitting inside and have it hang up. I'd take it to a brake shop you trust and have them check it out (they'll do that for free...)
good luck --
