M30 Steve »
https://forums.nicoclub.com/m30-steve-u17176.html
Sat Jul 30, 2005 7:32 pm
Hello mikoriad
i have had an on going problem with my ac /heat control. I replaced my controller last year they are known to black out. I could hit the dash and mine would light up. after replacing the unit I had poor heat/cool response. As it was -20 here i did a quick fix, i disconnected the mix door rod and connected a manuel rod i could reach by hand(right side of center console) now I reach over to adjust cold/ hot function. What I have done is bypassed the auto climate feature. The reason the auto control will not work is most likely one of three sensors not working. There are several post on this sit about a guy who rebuild theses units, do a search for climate control. The other trick might be to find a manuel control, some M30's came without auto climate control , meaning they had a fan control (speed switch) then a manuel lever for temperature. I was able to purchase an auto control at car parts.com for $40, I was lucky the part worked for me. Using my manuel system now I get cold AC and super hot heat. I hope to troubleshoot the system someday and get the auto feature back. The air door is easy to access through the center console, just pull the radio out. I do have a FSM for the car, let me know if I can send info. The diagnostics on this auto climate stuff are pretty involved. I am a novice (backyard mechanic) but I have learned a bit about the M30Thanks Steve
