Tampa G35 Sedan 6MT wrote:MY GF hates Nico... She says that I spend way to much time on here lol!
My wife says I'm obsessed with NICO lol.
I'm going to address quite a few posts here, so please keep up...
First regarding comparing the oil filter efficiency. The problem is that whether it be cotton, paper, or synthetic fiber, all of them are going to hold varying amounts of oil IN ADDITION to the filtered particulates.
With that being said, it would be better to use the same filter with different oils to see which oils caused more garbage to accumulate in the filter.
Another option, though still not quite scientific, would be to "wet" the filters prior to weighing them. If the filter medium is soaked with oil, then drained, the weight should give a moderately good baseline.
As for the comment regarding an oil that lasts 21k. Check out Amsoil. They have a couple that they say can last upwards of 35k miles. I'm still not sure if you have to change the filters during that time or not, but they also have multi-filter systems as well.
Steve,
Like G_Whizz (Sean) said, you're very valued here on the forums. If I could buy you a G, I would, then you'd have a toy to experiment on lol.
Jacko,
Just a little food for thought. My I30 is up past 280k miles right now with the original engine and transmission. It is on it's 4th owner. I'm not sure how the first owner (86kmiles) took care of it, but my mother who owned it up until 200k miles went to jiffy lube and wasn't always good about the intervals. I got the car when I was 19 and treated it like my very own race car. A few times I let the oil go past the oil's recommended life 5k-6k, then I started using the Mobile Clean 5000 and Clean 7500 and would frequently drive until the 5k or 7.5k marks on it.
At around 250k, I switched to Mobil 1 Synthetic and started using expensive filters. I found that the Mobil 1 got dirtier faster than the Clean 5000 or Clean 7500. I think this is due in part to the Synthetic's cleaning abilities. For the next 30k miles I used Mobil 1 or Mobil 1 EP. My oil always got dark within 2k miles and I didn't see any benefit from using the Mobil Filters or the K&N filter.
It's possible that the engine was just dirty inside, but I have a hard time believing that the synthetic wouldn't have cleaned it all out after 30k miles. I actually changed the Mobil 1 EP at 7500 miles because it looked so dirty.
As for your timing chain being original...They are supposed to last the life of the engine. Once your G is past warranty, I'd start considering an EP synthetic like Amsoil or Motul.
