jdm_master_X »
https://forums.nicoclub.com/jdm-master-x-u30964.html
Tue Nov 07, 2006 10:05 am
Isn't that strange? MrZabala, ppd_sileighty, and myself just finished my car. we're just wrapping it up, so hopefully, ill get pictures up and a writeup. definitely came out great.
Anyway, what happens from what I know is that the problem only occurs when the car warms up (in this case, closed loop operation). what happens is the car will jump up 500 rpm and drop back to normal, and repeat (as if i had aftermarket cams...haha). and oh yeah, the tachometer doesnt work (but it never worked well anyway, so i have my spare cluster to drop in anyway). i dont think the ECU would run the engine with a lumpy idle if its relearning its values.
parts of the blue ECU plug got painted a bit, so i was wondering how could i clean them? i dont know how to depin the plug one pin at a time, nor do i have a tool to do it. and there are still ground wires that i need to clean up because there is paint and some leftover bedline on them. one more thing i had to bring up. i threw away all my AC assembly, and i cut some plugs from the AC assembly that is part of the harness (AC signal blue wire green stripe i think?). would that effect engine operation? i know when wiring up the SR, that wire is also mentioned for getting the car running.
anyway, ill update you all on how the car is running. in the meantime, i would appreciate any feedback about this. hopefully, we can figure this out. thanks guys!
