lugnuts
qship96
Car: 1996 Infiniti Q45
what size socket do I need to buy to use a torque wrench to tighten factory wheels to spec? does it need to be an extended socket also?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
IM pretty sure its 21mm.....
Q451990
Wes is right... 21MM. I typically use a standard socket with about a three inch extension. That keeps the nuts from sliding back into the socket when you remove them.
Heath
qship96
thanks! sears is now 8.49 richer from my purchase! and,of course,found lugnuts overtightened from the rotate/balance job I had done last week! set t.wrench at 90 lb and tried to loosen nuts,no go! loosened and retightened to 80 ft.lbs all around.
szh
Car: 2018 Tesla Model 3.
qship96 wrote:thanks! sears is now 8.49 richer from my purchase! and,of course,found lugnuts overtightened from the rotate/balance job I had done last week! set t.wrench at 90 lb and tried to loosen nuts,no go! loosened and retightened to 80 ft.lbs all around.
Hmmm ... I wouldn't recommend using a torque wrench to loosen nuts - easy to damage the torque wrench that way, I think! Safest to just remove them with a regular wrench (regardless of whatever they were set to) and then re-tighten to the correct torque value - I set mine to about 84 ft. lbs. (to take into account measurement/accuracy error in the wrench and I'd rather have a little tight than a little loose!)
I always do this after I have had the wheels rotated or re-balanced, regardless of where it is done ... I'd rather get the values right, too!
Z
