RT22 »
https://forums.nicoclub.com/rt22-u137418.html
Wed Apr 21, 2010 4:31 am
if you can get the wheel off you have it whipped, just remove hub hit with a hammer and replace, it just slides in to back of hub. I had to replace one on back, easier as it can be removed with only wheel and brake drum removed. I put a stack of washers on the stud once in the hub and tightened the lug nut down to pull it fully into the hub tight
