lubricant
carloso
i have 2001 frontier supercharged does it need any lubricant ? if it does where can i buy it.
Big-Bird
Car: 2000 Xterra on 'Roids & 2004 Quest SL
If you are asking if the SUPERCHARGER itself needs lubrication then NO. The bearings inside this system are sealed and don't require external lubing.
As for the rest of the truck...UH YEAH! It needs to be lubricated, but there are several areas and lube types required for that so you may need to clarify your question a bit more if this is what you need.
