Post by NewToVersa » https://forums.nicoclub.com/newtoversa-u77303.html Fri May 15, 2009 12:04 pm
Post by hiimjered » https://forums.nicoclub.com/hiimjered-u98712.html Fri May 15, 2009 4:10 pm
I usually avoid WD40 on things like door hinges and mechanisms. WD40 is a little thin and could clean the grease off the parts. I usually use a good heavy grease on such mechanical parts.fjwagner wrote:WD40 on moving parts.
fine graphite in the lock mechanism if it gets sticky.
Return to “Versa Technical Discussions”
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
