Lube Change In transmission Help!
super_hicas
Hello, i have a 91 KA24DE and i have no idea where im supposed to fill my transmission after i drain it. ive never done a drop and fill on this car or any manual transmission car. Please help while i change my brakes pads and motor oil outside. ill come in to check on this thread. thanks. :help
DAEDALUS
Car: 1990 Infiniti Q45
I'm guessing you'll need to get a funnel and fill the transmission from the dipstick hole. Make sure the funnel end is small enough to fit. Or is there no dipstick?
daniel240
Car: cars/motocross
is it a manual?? cause if it is the easiest way is through the shifter. you just take out your shifter and pour it through the hole. there is an article about it in the faqs section.
super_hicas
ok i asked a friend and he said i have to buy a pen15 pump and pump it in from the side of the transmission where i see a lug. makes sense. ok thanks anyways guys.
TrunkMonkey
Car: 2000 Lincoln Navigator
super_hicas wrote:ok i asked a friend and he said i have to buy a pen15 pump and pump it in from the side of the transmission where i see a lug. makes sense. ok thanks anyways guys.
doing it that way is a complete pain in the butt, messy, and very time consuming. pull the plug from the side of the transmission, and fill it up through the shifter. it's full when the oil comes out of the plug hole.
trust me, you'll curse alot less doing it this way.
-demetrius
