TorJoe »
https://forums.nicoclub.com/torjoe-u294998.html
Thu Mar 12, 2020 11:09 am
I have read somewhere online that usually it takes only about 50 miles for LTFT to pop up again after reset. I have also read somewhere that LTFT stuck at 0 may have to do with EVAP problems (somewhere a sensor is not sending signal to the ECU), which can cause bad mileage because a bad EVAP valve can have the effect of a vacuum leak (air-fuel mixture gets vented outside instead of being routed back to the combustion chamber, thus creating a lean condition). I am still hunting for the source of my bad fuel economy.
I have just cleaned my PCV valve yesterday. Next I am going to look into my canister purge valve, which is quite accessible. If that's not it then maybe there is an issue with the vapor canister purge solenoid, which is less accessible as it is behind the left rear wheel.
I will get to the bottom of this and I am not giving up.
