This is all fine and dandy but this is a ls motor, there is a freeze plug at the back of the crank so that method does not work.StormyMatt wrote:I once had a problem trying to remove a pilot bushing from a stock KA24DE. The bushing had worn SO much that there was NOTHING for a jaw-type puller to grab onto. The solution? Get a tap with about the same diameter as the inside diameter of the hole. Cut threads out on the inside of the pilot bearing. Then get a large bolt that fits the cut threads, and place some washers betweem the flywheel and bottom of the bolt. Make sure the inside diameter of the washers (except the one on the top) is larger than the outside diameter of the bushing. Cranking down on the bolt will pull the bushing out more easily than you can imagine.
All of this pilot bushing trouble just makes me wonder about one thing. Specifically, why can't more automakers use a ball bearing style pilot bearing pressed into the flywheel rather than the crank (like Honda does)?
The method I outlined would work for an LSx as well. If you use the washers, no force is being exerted on the freeze plug.OutToWinPAHC wrote:This is all fine and dandy but this is a ls motor, there is a freeze plug at the back of the crank so that method does not work.
