xekushnr »
https://forums.nicoclub.com/xekushnr-u16901.html
Mon Dec 13, 2004 5:32 am
a vlsd stands for viscous limited-slip differential. like nismojason said, i cant really see any cons to adding a vlsd to your car.
with an open differential, taking hard turns with acceleration is much different than taking one with an lsd. with the balance of the cars weight spread out unevenly, there is an increased chance of one of your rears spinning faster than the other, conveniently spinning you off the road. on the open diff, there is nothing to stop this. a vlsd is operated by 2 plates spinning inside the diff at the end of each of your rear axels. there is a small clearance between the two plates. the diff is filled with a silicone fluid, and when you get into the aforemented situation, the one plate moving faster heats up the silicone, and "grabs" the other plate, causing the other wheel to catch up while still slowing the other wheel down.
your transmission has no effect on this.
