LSD?? Which way should i go for this????
overbaugh240
Car: Cars.. fast cars... i enjoy racing of all sorts
I know in the near future when i turn the boost up a little bit i will need a LSD. What did u guys do for this ? which is the best... i don't understand all the different kinds there are ??? is there any rear end you can use off any other nissans? i heard you can use a 300zx can u use an s13 240 lsd?? i just need a little help in which way to go in this area..any help would be greatly appreciated
Thanks,Chris
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
Yeah most nissan R200 VLSD's can be swapped. US 240sx VLSD are not too common, so you might as well go with either NA Z32/J30 or a silvia rear dif.
Personally i think, if you have the money, its good to go with a good aftermarket LSD. Helical gear LSD's and maybe 1.5 way clutch differentials are good for autocross. A 2 way clutch differential is prime for drag and drift applications.
So really it depends on what your goal are for your car and how much your willing to spend.
overbaugh240
J-Spec i really like road racing like hauling *** around curves and break loose some but still power through curves with ease ya know... but i also take alot of trips to the drag strip.... money is a little slim right now do to just finishing the swap.. so say if i were to find a wreck n/a z32 what exactly off of it do i need to make it work... will it bolt right up? any modification do i use my axles .. i really just never studied up on this part of the car... do u know of anywhere that has a z32 rear end? thanksChris
Onizuka
Since your on a budget, VLSD is the way to go (aftermarket LSD's cost $900+, and welding your differential will make your turning SUCK)
Here is a write up on the Infiniti J30 VLSD install (same differential as the NA Z32)
http://www.nissaninfiniticlub....22769]
enjoy :)
Phax
Car: Control dynamics
J-Spec did a good job of summing things up. If you're on a budget, go with the vLSD. For the kind of driving you want to do, you'd ideally want a helical LSD (Quaiffe).
swappedcrx
Car: building street cars for me and my band of misfits
I have tried 3 nissan rear ends, the stock open diff.(2.35 shorts on Falken ze-512 @28 psi), the j30 rear (2.09 same tire info) and the NA 300zx rear(2.17 same tire info) i really like the j30 unit for its longer gears the car real feels more powerful and can strech it's legs over my buddy's 8k+ rpm civic when we run similar times and mph. The z rear makes for a busy drive with all the extra shifting and makes finding the right gear in a corner clutch abuse.
f150intally
Using the Z diff should be no different than using the stock 240 diff since they are the same ratio.
- Jay
ride4lame
For grip driving like carvig turns and ish you want a helical/mechanical differential. Your options are Quaife and S15 differentials. They both utiliza a helical design meaning it has many gears inside that only actuate when power needs to go to both sides. Viscous LSDs or VLSDs are pretty good for all around. When friction inside the differential heats a 'goo' both wheels lock together. These are the cheapest, but usually the least reliable as many of them are OLD.CLutch style differentials are the most expensive usually, and you can get them from companies like Kaaz, ATS, and cusco. They have clutches inside of the diff that lock together and lock both wheels together. They are used most for drift and I don't think they are 'great' for grip driving. they are way better then open diffs though
You have mad options....it all depends on price thoughvlsd's are about 300helical s15 = 350ishquaife helical =800ishclutch style = 800+
hope that helped:)
Honda Hick
ride4lame wrote:quaife helical =800ish
I always thought Quaife's for 240's were like in upwards of $1200-$1500??:confused:
drifter
Car: Drifting, cars, etc.
I can get you a VLSD from a J30 for $350 shipped. Lemme know. :)
Phax
Honda Hick wrote:I always thought Quaife's for 240's were like in upwards of $1200-$1500??:confused:
The least expensive price that I have seen a for a new Quiaffe is $1200. I've looked for used ones a few times, and no one is selling them. It seems you either buy them brand new, or you buy a broken one, replace all the parts with brand new parts yourself, and pay almost full price.
swappedcrx
1.985 short time with j30 rear stock t25 with bolt-ons 3" exhaust all the way back fuel pump, Avc-r , Filter and front mount on get this part a falken Ze512 and a Vizzola(?) stock tire pressure 205/60r15 in fulkl street trim. Man you got me sold on gold old OEM nissan goodness. I also have both a z32 swap and a j30 swap for sale complete with everything (axles,bushings,nuts and bolts) 300 plus shipping
nissanrcer240
Car: 90 Nissan 240SX SR20DET
swappedcrx wrote:I also have both a z32 swap and a j30 swap for sale complete with everything (axles,bushings,nuts and bolts) 300 plus shipping
Im definetly interesed in the LSD swaps, can you get me a quote on shipping to Culpeper VA 22701?
