Lsd ???
Nissan dominates the drift scene - Always has, always will.
Sartin2drift
Car: drifting, working on my 240, hanging out with my freinds
Can someone please tell me what the best LSD is for the least amount of money ? will a vlsd out of another 240SX be better than aftermarket ?
jt1583
J30 lsd from a junkyard, not sure about the performance of the lsd sorry =/
ca18det_boy
The J30 is a decent LSD thats what I've had in my car for about 3 months now and like it. It's not as good as a clutch style but its a good diff for the price. Just make sure that you get the axles with the pumpkin. Your looking at a 6 bolt difference instead of the 5.
UncleBen
Car: '05 Infiniti G35 Sedan Sport
'98 Nissan 240SX LE A/T
'95 Nissan 240SX SE A/T
There are numerous s13 vlsd's around for not a whole lot.
vlsd out of a 240 or Z car or J30 aren't as good as a clutch type diff, which has already been said, but clutch type diff's are expensive!
Exar-Kun
Car: 2005 350Z
Yeha, the VLSD if its in good shape, is a great performance addition for around 300-500 dollars...versus the cheapest clutch type LSD(700+dollars)
and its quieter...but it will not perform as well, but going from a open to LSD at all(if it is in good shape) will help anyone quite a bit. I love my LSD.-chet
Hijacker
Car: '92 240sx Convertible
'94 F-150
it's a shame helical LSD's are so much...
Stuntman240
Car: 91 coupe
save money and get a deftforce. or look int the old z31 turbos they had clutch type diffs as well as some skylines.
ca18det_boy
Stuntman240 wrote:save money and get a deftforce. or look int the old z31 turbos they had clutch type diffs as well as some skylines.
really the older Z's had clutch style diff's out of the factory? Thats interesting but where could you get a rebuild kit from?
BuudWeizErr
tenkawa_akito wrote:it's a shame helical LSD's are so much...
Why, you wouldn't want it for drifting anyways. And normall, you can find S15 HLSD's on eBay for cheaper than VLSD.
Kaaz is cheapest clutchtype LSD. OEM VLSD... eh, good to start out on, but if you can, and you want to drift, just start with a 2 way. Few hundred more, but so much better. Way more predictable. VLSD sucks after you've driven 2 way.
Anand
Car: 95 Nissan 240SX
I second that... I have a VLSD out of a J30... I wish now I would have just saved up more $$ for a 2-way like KAAZ... would have been much much happier..
Although, VLSD is not *bad* it just starts to suck once it's gotten really hot.. it doesn't grip as much...
Exar-Kun
Car: 2005 350Z
a good oil and heat fins will help that problem a lot anand.I only paid 250 for my LSD(and it locks better than most i;ve driven). :)-chet
Anand
Exar-Kun wrote:a good oil and heat fins will help that problem a lot anand.I only paid 250 for my LSD(and it locks better than most i;ve driven). :)-chet
heat fins I have not tried yet but the oil I have
I change the oil after every 2-3 events with the LSD add... I change it with Mobile 1 oil too..
Exar-Kun
Car: 2005 350Z
get some redline shock proof heavy :)great stuff man...absolutely great.phase-2 had the differential covers that allow a bit more oil and better cooling :)-chet
daniel
*shrug*
instead of paying extra money you can use the z32 n/a diff cover.its finned.its baffled.
for oil..save yoru money
just get some NEO gear oil..$44 a GALLON and throw some ford additive in there from HD diesel trucks
as for lsd
vlsd = suck1.5 way = rock2 way = rock
go ahead and pick
Z31 kouki turbo has clutch type. this swaps in. use a 200SX turbo R&P to keep 4.11 gearhave fun
ca18det_boy
Black240 wrote:Although, VLSD is not *bad* it just starts to suck once it's gotten really hot.. it doesn't grip as much...
but isn't that how they work...it gets better as it heats up........
daniel
negative returns.
Stuntman240
Car: 91 coupe
i think u can get a rebuild kit from courtesy nissan, for the z31 clutch types
DriftFactory
Car: Evil S13
The thing about LSD's is that you get what you pay for. Every type of LSD handles differently. I prefer KAAZ. I think that they have the best feel and are the most reliable. That is the reason that I chose to carry them. There really isn’t a better LSD out there for drifting. Even the NISMO LSD is not as responsive and fluid as the KAAZ with the RS plates.
Return to “Nissan Drift Forum”
