lsd ?
n9neLiveZ
Car: 1995 Nissan 240sx S14
Ok Im gonna install a ls1 motor in my 240 but can I use the same diffrential with a better nismo or a kazz or cusco lsd in it or do I have to get a diffrent diffrential :gotme
zachattack_5491
Car: Pignose S13 Redtop SR
You can do whatever you want with the diff. With an LS1 swap there is no need to swap out diffs I don't think.
nissan_star
Car: 2000 maxima se and 1993 240sx vert (5sp!!!)
Leave the housing, change the insides. IMO getting a NISMO KAZZ or Cusco is getting a different differential.
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
umm, what does the differential have to do with the motor swap? get your driveline fabbed to fit with that trans. if your wanting it to be locked or lsd look for the 30 different options you have for the 240sx. the choices and work for rear ends are easy and brainless compared to the other problems you will run into with that swap. i would highly suggest becoming very good friends with someone that works for "painless" wiring. lol!
n9neLiveZ
thanks guys thats good info
