E7-S14 »
https://forums.nicoclub.com/e7-s14-u42538.html
Sat Jan 03, 2009 7:42 pm
1. What is it going in?2. are the output shafts 5bolt and 6bolt
if its going into an s13 then the back cover and front bolts will bolt to the carand if your output shafts match up then its a bolt on and go affair
if not you may have to source correct axles
your post was hella vague so i tried to go over everything.
