lsd ?
KaDrifter
I have a 96 240 but when i power brake it both tires spin and leave marks, but it isn't a SE, it's four lug, the vin plate dosn't say it should have one, but it doesn't have abs, and it has the white face SE gauges and alloy rims, bought it used stock. Does an open diff. spin both tires?
biggie
No, you might have had wet tires or something. But if it is a non-SE and stock it is without a lsd.
KaDrifter
nope dry tires
corn322
Car: 1993 240sx
if both wheels have the same amount of traction, they will both spin.
did the previous owner swap in a lsd?
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
to test for lsd u dont do it in a straight line...duh, cuz that'll more than likely give equal traction...
u take it to an empty parking lot...lock the wheel one direction and then floor it...then count the skid marks
-HyJynX-
Car: CArs...cars..
or lift the rear of the car..spin one tire and if both tires spin the same direction u got a LSD..
180fan
Car: 89 fastback
Would that test still apply if it's viscous? I was under the impression that the viscous locks up when the slippage causes the fluid to heat up thus causing the lock up in the LSD. So would that test still apply?
Tweaky_Tom
Does '95 SE have an LSD?
