Postby
danielsca »
https://forums.nicoclub.com/danielsca-u7781.htmlWed Jun 04, 2003 4:30 am
Also most stock SE's may have an LSD and all 300z's have them which with a little sweet talking will fit inside your dif. Good Luck.Try JSpec.com they may have one or two avalible.
Postby
Ace »
https://forums.nicoclub.com/ace-u376.htmlWed Jun 04, 2003 4:30 am
Some LSDs from junked 240s will work. You need to find one with the same output shaft pattern. Also it doesn't matter if you have a SR20 or not the differential bolts to the driveshaft.
