lsd
95niss240
Car: 1995 nissan 240sx
what is the best lsd i can get for my 95 240?
cdlong
Car: '95 240sx
i don't know, (actually i do) but either way, it certainly won't be in the KA engine forum.
check the 240sx general or tech section or better yet, search!
Red coupe
Car: 92 Nissan 240sx Coupe
probably like one of the computer controlled electromagnetic ones they use in rally cars..I don't think they make any for the 240 already but for a few thousand you might be able to get one adapted...If your not looking to spend thousands of dollars you might not be able to get the best. Maybe some hint of budget and what you will be doing with it would be helpful? Also try the large blinking button in the upper right corner.
Chezedik
Car: 1991 Nissan 240sx
HA!
s14 2510's
Car: 96 s14 rb26 2510's fully built, 91 s13 sil truck rb20 in works
welded = $100Cusco nismo lsd's go for around $800If your cheap weld that ****. If you got bling buy nice 1.5 way
skydragoness
Car: 03' 350z Touring 6spd
92' 240sx 60k survivor :)
s14 2510’s wrote:welded = $100Cusco nismo lsd's go for around $800If your cheap weld that ****. If you got bling buy nice 1.5 way
and something completely unstreetable
Chezedik
Viscous is cheap, but I think my next investment will be helical. I would be willing to trade my viscous for 150+ your old one.
s14 2510's
I have rocked a welded in my s13 for 15k and they are not that bad. A 240 is so light you dont get mutch chirp unless you are rocking 9-11" wide tires. I would own one any day over a viscous. Then again I have a car built strictly for winter so my 240's never see anything bad. Gota have fun in the snow. Im the kind that likes to drift and drag or just plane mess around when I can. I know 5 people that I can get you emails to that have a welded diff in there 240 and daily drive and would never go back to even a cheap lsd. All I have to say is dont bash unlees you have tryed one.
Chezedik
Yeah, I kept my stocker so that I could one day try the Phantom Grip. I like the idea. But be careful, it is only a good idea if you have enough torque to make a wheel spin. Otherwise, you will have enough TQ to break parts, but no slip in the system.
TrueSlide
Car: Stuff
Kazaa and Cusco are going to be the best overall. Just for steet use, a 300Z N/A will do fine.
Do not weld, I guarentee you will regret it.
Edub1
Car: 89 240sx KA-T
What does this do to your handling & cornering? Does it chew up tires? I'm going to be getting some top of the line BFGs and I don't want them messed up.
Red coupe
welding? yes with your axel locked it gonna make one of the wheels scrub on the ground. Read up on how a differential works and you will see why.
cdlong
Car: '95 240sx
the car will either understeer or oversteer, no in between.
well, i guess there would be some times when it isn't sliding in one way or another, that when one of the rear tires is scrubbing. you can imagine what that does for tire life.
Sil40_Mayhem
Car: 1995 Nissan 240SX 5spd
1992 Acura Integra LS
I heard the best lsd you can get for a 240 was the stock ulsd.
.(UnLimited Slip Differential)
Edub1
Car: 89 240sx KA-T
I know how a differential works - that's why I asked.
I think the J30 rear end is the one to use.
GhostDriver
Car: 1991 Nissan 240SX RMS13
Be forwarned, the 3.9xx gearing will make your 240 noticably slower. Trust me I know. It does get better mpg and cruise better
It does lock up however, but if I could afford it I'd get a 1.5 or 2 way from Cusco or Kaaz or ATS or Quaife (NA Z32).
