So you are saying that the rear covers are exactly the same on open and VLSD? I know the open diff cover has fins but it only has like 8 or 10 or so widely spaced fins.NY S13 SR wrote:VLSD was an option on 91-94 240SX, it was available without HICAS. All HICAS have VLSD.
Rear cover fins are on open diffs also, you can't tell VLSD from open just by the fins.
It should be hard to turn the axles opposite from eachother, but if the VLSD is worn out / high mileage it will be easy.
Very few non-HICAS S13's have VLSD, I have yet to find one that wasn't swapped in by the owner.
You cant tell by looking at the VIN, I run the VIN through Nissan and I learn all the options on your car. But if your going to be an a$$ about it then just figure it out yourself.DrifterBoy240 wrote:why dont you tell me how i can tell by the vin and then ill find out if it is an open diff or VLSD
