Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Fri Nov 19, 2004 9:38 am
as long as you have the output shafts from the HICAS unit, you'll be fine. The Open diff and V LSD outputs are different lengths internally, but use the same flange, so your axles will bolt to the V LSD outputs.
One thing of note is that you will need a new driveshaft. The HICAS unit has ABS, and the pumpkin is an inch longer than the non-ABS pumpkin. You'll need the shorter ABS driveshaft to accomodate for that.
