jr_ss »
https://forums.nicoclub.com/jr-ss-u34795.html
Mon Mar 20, 2006 7:10 pm
Using grease was probably a bad way to figure out where the gear teeth are meshing. It leaves a very vague area of where the teeth actually mesh. A better way to see the wear pattern would be to use a wax crayon or paste type material that is brushed on, of say yellow or so and "paint" a few teeth on the pinion and the ring gears. Install the pieces do a few revolutions maybe 1-2 max. Check to see where the "paint" was rubbed off. It should leave a nice pattern in the middle(the white spot on your picture). Do the best you can to get it towards the middle of the ring gear, it'll cut down on wear and tear a significant amount.
