lsd R200
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
l28ets13
Car: datsun 280zx
I have a 79 280zx, Im assmuming my differential is a R200 i think.Now yesterday i was going about around 45 50 mph, and took a right trying to break it loose and i heard a pop. I stopped and looked at my diff nothing was broke on the outside. But when i drive a grinding and then a pop noise happens, if i turn left the noise goes away or is slightly less, if i turn right it is massively worse. Today i pulled the diff cover off and evrything seems to be turning and rotating right, but i can sence this rough spot while turning the axles. My first guess was spider gears but everything is there im guessing something is bent.
If anyone has had a similar problem or give me a good guess to what might be, if not im going to just weld the diff and see what happens.thanks phillip
Modified by l28ets13 at 5:57 PM 3/29/2010
Modified by l28ets13 at 6:14 PM 3/29/2010
l28ets13
Car: datsun 280zx
solved it was a hub problem, Nevermind
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
I was gonna guess a driveshaft U joint issue, which if you have U jointed half shafts then you have the R180
Return to “Datsun Z Forum”
