LSD questions
Nissan 350z / Nissan 370z technical discussion forum: Maintenance, performance, installations, modifications, how-to's and troubleshooting.
Mikky350z
Car: Nissan 350z 2004
I have a 350z 2004 Base coup. I have the button case for the lsd button but no button. How would I go about installing a button and would that follow with a possible new lsd? Also when I burn outonly 1 tire moves. I understand that with Rx-8s they have the button and my buddie can turn it of and burn out with both tires fine.
BusyBadger
Car: '92 Nissan 240SX
'05 Nissan 350Z
'13 Nissan Juke
Only one tire spins because the base model 350Z has an open differential.
When you say button case are you talking about the area on the dash where the TCS/VDC button goes? Installing a button here isn't going to anything, it would be as useful as installing an intercooler with no turbocharger on your car.
Your best option for upgrading the open differential on the base model Z is to use the Quaife helical differential since it works fine with the open diff output shafts. Most of the conventional clutch type lsd's will only work with the OEM viscous output shafts.
And if you live in CT I'd advise installing the lsd and mounting some winter tires before snow season starts, or keeping it in the garage until the spring thaw.
dasoupdude
Car: 2005 Nissan 350Z
Mikky350z wrote:I have a 350z 2004 Base coup. I have the button case for the lsd button but no button.
I have a base model as well.
It's not really a button for the lsd to just "activate." It's always active (if equipped), the buttons are the vdc and tcs.
That sales pitch description made me feel so low
Ah, the feel of an open diff and lsd are day and night.
40flash
Car: 240sx 95 S14 VQ
I think the infinity j30 came with a helical diff in a R200 short nose diff case. Will that one work in a base model 350Z? Will the stock 350Z gears bolt onto the J30 helical LSD so I can retain the stock ratio? I am thinking this should be nearly a bolt in but don't know for sure. What do you think?
BusyBadger
'05 Nissan 350Z
'13 Nissan Juke
40flash wrote:I think the infinity j30 came with a helical diff in a R200 short nose diff case.
No.
The R200V from the J30 (and Z32) is a viscous diff similar to the one in HICAS equipped 240's except with a different drive ratio (J30 is 3.92, 240SX is 4.08).
Mikky350z
Is there a full pozy avalible I kind of want 100% to each tire not 50/50.
350z 2004 base
dasoupdude
Mikky350z wrote:Is there a full pozy avalible I kind of want 100% to each tire not 50/50.
350z 2004 base
I don't think you can output 200% to the rear wheels.
Return to “350z / 370z Technical”
