evildky »
https://forums.nicoclub.com/evildky-u13100.html
Sat May 17, 2008 8:57 pm
only the base model had an open diff, all others gor viscous, the whole 1 way 2 way thing is lost n me, it's somethign the younger guys used to describe the action rather than type and breakaway, the stockers were viscous, I think brake away is like 80 ft/lbs, the old Z31 clsd's were clutch typ with 40 lb break away, but yu could add frictn disks and shims to increase breakaway torque, the Precieion Gear power brute I believe is a clutch type with 80 lb break away, the quaiffe is just a name brand, I beleie theris is a clutch type, there are hellical diffs available but can't remember who makes it, the OBX units I hear use the same carrier but crappy shim material, supposedly you can replace their shims with quality shim metal and have a good quality diff for cheap, the reason it's important to know wether your car was equipped with a factory diff is the viscous uses unequal length output shafts so a clutch tpe used in place of a stocker woudl have to be splined to accept these unique shafts, all others are designed for use with equal length output shafts
I believe the base model also had a steel driveshaft and I believe all othersgot the CF driveshaft
and good luck finding someone with a LSD in stock in FL, I'd imagine Z1 might have one in stock just up the road a bit in GA, what part of FL are you headed to? you know it is like 450 miles miles long and 350 miles wide?
