onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Tue Nov 27, 2007 11:50 am
what vlsd are you running?
If it's a j30 vlsd, (and there is the rubber bushing part inside), you only need the proper bolts & metal washers that go around the front mounting points - which can be found via some of our sponsors (CourtesyParts, etc, etc).
If it's some other random vlsd missing bushings... the proper (and easiest way for me, at least, based on the info you've given), is to swap the internals of the vlsd w/ my current housing. Swapping the internals will require a couple seals/gaskets that you can also get from our sponsors. The actual procedure can be basically found by looking @ the LSD swap articles on this site/google/etc. You should be able to make it out from there.
You do NOT want any play from the diff -> frame. There is a lot of torque that gets passed through that area & you can very well crack your subframe (happened to one of my friends who ran a j30 w/o the proper metal washers).
But really now... you suxors @ the searching... and common sense.
i.e. if you just searched on how lsd's worked in general (through google, howstuffworks, etc), you would have found your answer from legitimate sources w/o having to question whether or not the info provided is true. For your 2nd question, you would have found the answer if you read up enough about lsd/vlsd swaps etc depending on which vlsd you have & see what ppl have done. If you are missing a part from completing your install properly, you should realize that you shouldn't be ghetto-rigging/jerry-rigging/etc-rigging your setup if you care about your safety, long term durability, etc.
