sasgha wrote:240marcuSX- how do you have an open diff? whats it mean in other words.
im curious too, what is the differences between the three different types of lsds?
do certain cars have a helical or clutch type? (ie j30, z32, etc)I'm just looking for something that will be easy to install. I know of someone that used the 300zx axels and lsd, he has to shorten the axles, balance them them install it all. I dont want to do all that work.
I never heard of using the 300zx axles with lsd swap..
Lots of how-to websites mention that you should use the j30 axles with the 300zx differential. You won't have to do all that work if you use the proper axles.
And if you want to know the difference between the different kinds of differentials, you should do a search on this site, on google and read the article on howstuffworks.com... you should at least know what an lsd does if you plan on putting one on your car
