BusyBadger »
https://forums.nicoclub.com/busybadger-u28281.html
Sat Dec 12, 2009 4:59 am
The VLSD will fit but it won't do you any good - the output shafts used on the base model Z are different than the ones on the models that have a VLSD so you would need those in addition to the VLSD.
I'd pass on installing a VLSD unless the costs were next to nothing, especially on one that had 60K miles.
I don't know what your end use of the car is, or what kind of money you're ok with spending but you should at least take a look at the Quaife HLSD. It's the most transparent of all available aftermarket LSDs, is low maintenance and it works with stock output shafts on the base model.
