LSD question on the 240sx
rn240sx
Car: 12 Frontier V6 (supercharged)
98 240sx ka-t (fully built)
09 Ninja 650R
06 Suzuki S40
15 Hyundai Santa-Fe 2.0T
Do all the LE models come equiped with LSD from the factory..??If not, then what do i need to look for in the LE models that can tell me if it does have LSD..Keep in mind im shopping over the internet and i wont be able to physically look or test it to see if it has LSD..
ThanksRobert98 240sx-t ( wrecked and totalled out .......... )
thelinja
VLSD/ABS was an option with the SE/LE model. There are no physical differences except for I think that a higher percentage of the kouki models actually had VLSD/ABS in contrast to the zenkis. Hopefully the owner would know. Good luck in your search though.
silvia tunner
Car: 1995 Ruby Pearl s14
I have an LE with ABS but i donno if i have VLSD or not how can i check?
http://www.cardomain.com/id/projectmaroons14
Thee 240sx Owner
Car: Canadian 89 240 with LSD/stock no ac/ and 4 motor swaps
there should be an orange stick on the differential in the back or the hard way would be to jack up the rear end off the ground and spin one tire.. if the other goes the same way then you have lsd.. if it turns the opposite then its an open diff
SoCalS14
Car: My car...duh
only 95 Zenki's came with the ABS/LSD as a combined package...I believe...after that they were two seperate options...
I have a question though...is the factory LSD a One-Way?
Fenvy
Car: 2005 350Z Base 6MT
what year LE? my 91 LE does not have abs nor lsd, I suspect all s13 are like that except the super hicas version
corn322
Car: 1993 240sx
the way a viscous LSD works I'd imagine it could lock both ways.
whiterps13
Car: white LE hatch
are you refering to s13 or s14? my 92 le has no lsd or abs
silvia tunner
i have a zenki 95 with ABS
SoCalS14
Car: My car...duh
Silvia tunner, you probably have a LSD.
Corn...Not sure about that...I think it would be one-way...
