LSD question for my 92 240
driftin8ez
Car: 92 Coupe, Turbo Miata
I found someone selling a VLSD in my area when i asked for a description he wrote this:
MINT CONDITION JDM
V-LSD FOR YOUR 89-94 NISSAN 240SX SILVIA
mint condition 1:4.08 V-LSD for your 89-94 Nissan 240sx. As you can see in the picture number two, the LSD itself is in mint condition.
Now my question is will this bolt onto my car without anything else? Do i need diff out puts, drive shaft, or anyother oart i dont even know exists?here is a pic
driftin8ez
pic1
driftin8ez
pic2
BaliLover
I think you'll either need output shafts or the axles that fit it. The output shafts on every S13 I've ever seen had a different bolt pattern. That LSD has a 5 bolt 5 pointed star shaped pattern, and the S13s I've seen had a 6 bolt 3 pointed star shaped pattern.
candela
yep, it will bolt right up with no hassles if its from an S13, however you will need the silvia axles OR to get some VLSD output shfat from somewhere else (very expensive at the dealer)...
