Mike09 »
https://forums.nicoclub.com/mike09-u536.html
Thu Aug 04, 2005 4:40 pm
Alright I have a JDM 5 bolt VLSD from an S13 w/ABS. I want to install this into my S13 89' no abs. I have both output shaft's from the JDM diff but only 1 axle.-My Question is To install this diff can I use my OEM axle's and output shaft's?? Or If 1 JDM output shaft is longer, can I just use 1 jdm axle on that output shaft, and use my OEM axle and output shaft on the other side.Kinda Ghetto but can't find another axle for cheap??????????????
-Do I need to swap rear cover's?
-Can I use the stock driveshaft??
-There is mixed answer's on the last 2 so I'm looking for a clear answer?
