Lsd problem
Kouki_Projekt
Ok so i have a Kaaz 2-way lsd and it works(both wheels lock up and burn ) but the thing is that it crackles everytime at a slow turn or when i like go slowly up in first gear uphill. My question is that suppose to be normal or is it a bad lsd? and it does have a lsd leak so could that be the problem? idk
kouki_hmongster
Car: Want 97 kouki
From what i remember it makes a clicking noise while turning or whatever you want to call it. i think the 1.5 way doesnt do that, not exact about the 1.5
Tyler
Car: 1989 240sx HB/1992 240sx coupe/1998 s14
its normal for it to click and stuff, but fix that leak and dont forget to change your gear oil often.
jokesterR6
Car: 1993 Nissan 240sx
yeah friend of mine had a 2 way and it made some weird noises at low speed and turning, fix the leak and check it weekly but its fine
jerryk
Car: 1990 240SX
Use pure oil non-additive and change every 3000k miles. Motul 90PA.
