compactfean wrote:The reason you can not find an answer Is because no one is brave enough to try it. I personally Am going to put in an arb locker in my car that is meant for the r200a front diff. I have looked at the specs from both and it will fit with minor mods. My problem is finding one for a reasonable price. If someone knows where to get one for like 5 bills let me know and I will start the how to sticky for the best option ever!
compactfean wrote:I'm totally down to be the Guinea Pi. g. I've looked all over the 4x4 sights trying to find someone bailing on there locker project but no luck.
jgauspohl wrote:I know the ring gear is 200mm I'm not questioning that but you don't hear of people using the diff chunk itself without different halfshafts especially in a 240. I've seen a writeup for the pathfinder but even they are only using the casing and ring and pinion. And some of the older pathfinders "might" have clsd from what I've read. I say you check the spline counts on xterra, pathfinders and such...pretty sure the halfshaft diameters are different too. Don't you think if the spline counts and diameters were the same more people would've went this route to save money?
it's possible but it depends on the year..but the length/diameter and steps on the halfshafts I'm pretty sure aren'tI know for sure the spine count for the r200a is the same
