LSD or standard Diff
drews240sx
Car: Family, racing
What is better for track GT racing (cornering) a LSD or a standard diff.
ThanksDrews240sx:ylsuper :ylsuper
Clatch
Wouldn't the obvious answer be a 2 way LSD?
cdlong
Car: '95 240sx
no, because some people think a 2 way is too aggressive. a 1.5 way would be good for track or an HLSD or even a standard VLSD would be good for light track use if the budget is tight. either way, an LSD is better than an open diff on the track.
drews240sx
Car: Family, racing
Thanks for the answers,
PS: If it was obvious to me I would not have asked!!
What is the diff between the HSLD and VSLD and can I bolt it into my 1990 240SX.
Thanks
cdlong
Car: '95 240sx
HLSD-Helical Limited Slip Differential, found in the S15 spec R or something, whatever the top of the line is. do a search to get more info. uses worm gears to transfer torque.
VLSD-Viscous LSD, the LSD in all RWD nissans (option on the 240sx, standard on everything else) from skylines, j30s, Zs, Qs, 240s, etc. there are quite a few versions so search for that too. uses viscous clutch packs to transfer torque.
drews240sx
Car: Family, racing
Thanks to you for answering, does anyone know if I can bolt the VLSD straight into my 1990 240sx, stock transmission and rear end.
Thanks :ylsuper
cdlong
Car: '95 240sx
yes, lots of people know if it can or not, and you would be able to find out by searching.
or i could just tell you. yes it will. but search anyway, like i said, there are a few versions and some work better than others.
