lsd knowledge
gotspeed
Car: 96 nissan pathfinder 97 infiniti J30
Well I jacked up my 97 J30 in the rear with both wheels off the ground and I turned one wheel and the other went in the opposite direction, then I put the car in D and then the wheels spun in the same direction. Which one means that I have LSD? I saw one while searching but there was no definitive answer, Hopefully this one can end with an infinitive answer and not a bunch of "I think so's"
yodawill2000
Car: 94 Infiniti J30
Uh and the question is ???
If its "do I have LSD" then yes .All J30's came with Limited slip rear ends.
Elisha
Car: Infiniti J30
i think he wants to know if his LSD is working or not. not that if he has it or not.there is a way of finding out by jacking it up and spinning the wheels but i'm not sure how to tell.
yodawill2000
Light em up then.If it fish tails its working.
gr8scott72
Car: 1994 Infiniti J30t
yodawill2000 wrote:Light em up then.If it fish tails its working.
Not always true. You can have an open diff and still fish-tail.
You can drop one wheel off the pavement and then light them up. The one WITH the traction should still spin and not just the one in the dirt.
brandonjustice93J30
Car: 1993 Infiniti J30
yodawill2000
I w
True ..but if you have two lines of Goodyear on the pavement
gr8scott72
yodawill2000 wrote:I w
You can still burn both wheels even with an open diff just not every time. If the surface is about the same for each wheel and enuf power is applied, both will spin.
yodawill2000
Ahh quit being so smart ... nuk nuk
