LSD install problem.
mikeroy420
Car: 1990 Nissan 240sx
I just had my limited slip differential installed at a dealership, and now I'm not sure if the axle output shafts were installed in the proper sides. I'm having the same problem as the one in the following link Cusco 2 way problem - Zilvia.net Forums. Does anyone know which axle shaft is susposed to be closer to the ring gears? the shorter one or the longer of the two?
del82
Call the dealership and get the parts counter on the line, and ask em if the replacement output shafts are the same for each side, if they are, you're fine.
Enjoy re-learning the car's limits (= they handle a lot differently after putting in a LSD.
