IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Thu Sep 30, 2004 6:35 pm
actually, the dont fully lock the wheels.
the insert its a two piece bar of metal with springs inbetween the halfs. the spring causes the two blocks to preload the pinions in the differential so the wheel with less grip wont spin as easily.
it takes more of a traction differential between the two drive tires before one will spin.
BUT it has a limited lifespan, only works to a point [no where near as good as a real LSD], and isnt all that good for the diff.
i never recommend them. for the amount it costs, and the amount of work to properly install it, your only a few hundred short of a real LSD.
get a used VLSD if its a daily driver.
the difference between an open diff and a LSD on launch is around .1 g's.
the difference between regular all season tires, and good sticky tires is even greater.
basically, its a waste of time and money.
