LSD ID?? + install Q's. I searched
Mike09
Can someone Identify this diff. I believe it's a 300zx NT but if someone can clarify that'd be awesome!!! Also to install on my S13 90' w/ SR20 non LSD diff. Can I just use the hub flange's in the pic's and install the stock axle's into the joint's in the pic. And do I need to swap the stock Cover?
Is that all? The rest of the bolt's should just fit right.?
Mike09
another.... BIG *** pic's sorry!!
Dookie
Car: 1993 240sx Coupe
Looks like an R200V to me, thats the diff in the 300zx, 240sx, j30, etc, many other nissans. Im not sure about bolting that CV flange to the axles, cause I heard that the 5 bolt axles were a bit bigger, but they probably should fit.The 300zx n/a is the diff to use in the 240 because it has the same gearing as the stock 240 diff
Mike09
Any1 have any for sure answer's on if the Axle's will fit and if the it's a straight bolt in?
VitaminT
Car: 93 240sx SE
It is NOT a 300zx NA diff. I believe that all z32 had ABS and the zx diff I had a while back had ABS sensors on both of the output shafts. That looks like a JDM 180sx diff or something. Seems like some of the JDM diffs that fit our cars have those 5 bolt output shafts.
Also note that the 300zx (even the early 90 model) had rubber bushings in the 2 front mount tabs leading me again to believe that it isn't a z32 diff.
I have heard that you can have the 5bolt pieces mated up with your axles to make a set of axles that will work with that diff and your car. I would expect this to run about $50-100 to have someone try to mate them and put fresh boots on the joints.
