Lsd Help
jjns13
I bought a used Nismo LSD and it is just the LSD itself. My question is what addtional parts do I need to install the LSD into my diff.? I read some where that I will need two "short" output shafts for the diff.,and that a factory VLSD has one short and one long, and an open diff. (which I have now) has two long. Is any of this true? Also, would I need anything else to install it or would that be all?
jjns13
nobody with any clue?
jjns13
bump
180fan
Car: 89 fastback
you'll need the bearings for the diff if it didnt come with it, and to check if the flanges on your stock diff will fit.
