sworxx wrote:I was considering upgrading to an LSD for a race car. I predominantly race on road courses and would really like to get rid of the inside wheel spin. I just wanted to see if anyone out here has one, what kind and what your experience is. I was considering a 1.5 Way KAAZ or a 2 Way set at 80% as my wife also uses the car for Driver's Ed. How drastic is the change from open diff to LSD? I appreciate any input. Thanks.
UHhhh don't u want the inside wheel to spin?sdwyzs14 wrote:many will tell you that for a purely road race car, a helical will be the most optimal diff to use as it transfers the power to the wheel with the most grip, instead of locking and spinning both (1.5 and 2 way), or spinning the inside(open)
if he wanted the inside wheel to spin why would he upgrade from an open diff? generally you want BOTH wheels to grip on all corners. a spinning tire = less traction = bad(well maybe not bad, but they wont be better than one with all traction) lap times.and yeah what the hell.. why are kids learning to drive on a race car? not sure how i feel on that. but cool.bboyp1ng wrote:UHhhh don't u want the inside wheel to spin?
Yeah i understand what ur saying but he's saying inside wheel spin? That's not even possible on an Open Diff, cuz on an open its the outside wheel where all the power is going too.LayNLow240 wrote:if he wanted the inside wheel to spin why would he upgrade from an open diff? generally you want BOTH wheels to grip on all corners. a spinning tire = less traction = bad(well maybe not bad, but they wont be better than one with all traction) lap times.and yeah what the hell.. why are kids learning to drive on a race car? not sure how i feel on that. but cool.
AmoebAssassin wrote:A helical is great for a road car because it is silent and smooth in operation. If your wife is using the car to teach new drivers, get a helical.
However, for a road racing car, I'd recommend a clutch type differential. People assume that a helical has the capability to infinitely bias torque between the drive wheels; this is not the case. Once you exceed the maximum frictional force between the planetary gearset and the differential housing, the torsen will not be able to bias any more torque. For high power track cars, this limit is far below the amount of torque being delivered to each wheel, and the diff will act like an open diff.
A clutch type diff can support a fully even torque distribution between the drive wheels, or at least fully even minus the breakaway torque rating of the diff. Additionally, clutch differentials will be more predictable than a helical diff, which will bias torque based on surface roughness, tire temperature, rear tire slip angle, among a number of other factors that affect the amount of traction each tire can provide. In racing, while it is great to be able to turn hot laps, consistency is the name of the game: this is where clutch diffs shine.
Most pro road race cars will run a spool or a 2-way. Idiots will tell you that this causes understeer, but since you are building a race car, im sure you're knowledgeable enough to know how to tune out understeer using roll bars and/or roll center adjustment.
Idiots will also tell you that clutch diffs will cause your tires to spin or wear faster, but good drivers have good throttle control and will be able to regulate wheelspin. And I doubt tire wear is that big of a concern if you're choosing to build a track car.
I'd analyze your driving style and decide between a 1.5way or a 2way clutch diff.
-Neel
an open diff is like electricty. it takes the path of least resistance. on the exit of a corner, alot of the cars weight is on the outside of the turn, meaning the outside wheel has the most traction and the inside has the least. the inside, being easier to turn, will be the one that gets all the power because it has less traction than the outside wheel. its like trying to do a burnout with one wheel on cement/asphalt/something with traction and the other on ice, youll just spin the one thats on the ice.bboyp1ng wrote:Yeah i understand what ur saying but he's saying inside wheel spin? That's not even possible on an Open Diff, cuz on an open its the outside wheel where all the power is going too.
alot of 240's run with a spool, see all these threads talking about people wanting to weld their diff and others saying they have done it, its nice, etc. a welded diff is basically a spool.574-240sx wrote:
finally someone that knows what they are talking about. I was getting pissed off and going to say 2way or spool but I have only ever seen 1 spool in a 240 before. There was an article not too long ago, I can't remember where I seen it. I'm going to look for it.
Yes, the helical is your best bet for a street car that sees occasional track duty.Seto wrote:hmmm, thats a pretty good explanation, answered most of my questions buddy, i was looking at OBX on ebay, people dont reccomend those, im going for the S15 OEM helicals, i really want quiet, better then open diff, once a blue moon track running, occasional burnout/donuting diff setup. Am i looking at a helical?
how long do these last? does oil need to be chnaged very often?
Just like ebay turbos are basically quality turbos.LayNLow240 wrote:alot of 240's run with a spool, see all these threads talking about people wanting to weld their diff and others saying they have done it, its nice, etc. a welded diff is basically a spool.
I get what ur saying with least resistance and when ur turning hard the least resistance is in the inside wheel since its lifted off the ground. But isn't it when ur tire breaks traction the outer wheel will be spinning the fastest (in an Open) since it has the least amount of resistance?LayNLow240 wrote:an open diff is like electricty. it takes the path of least resistance. on the exit of a corner, alot of the cars weight is on the outside of the turn, meaning the outside wheel has the most traction and the inside has the least. the inside, being easier to turn, will be the one that gets all the power because it has less traction than the outside wheel. its like trying to do a burnout with one wheel on cement/asphalt/something with traction and the other on ice, youll just spin the one thats on the ice.
There is no maximum frictional force within the differential. The more torque that is generated by the car, the more frictional force there will be, and so it will still function.AmoebAssassin wrote:However, for a road racing car, I'd recommend a clutch type differential. People assume that a helical has the capability to infinitely bias torque between the drive wheels; this is not the case. Once you exceed the maximum frictional force between the planetary gearset and the differential housing, the torsen will not be able to bias any more torque. For high power track cars, this limit is far below the amount of torque being delivered to each wheel, and the diff will act like an open diff.
