lsd fluid question
MyNISMO314
Car: 91 SE Coupe w/red top sr20det(currently for sale)
just got a 97 j30 diff to swap into my s13...i was wondering which fluid thickness is the best for the diff and how much of it should i get...i see the two drain plugs on the pumpkin of the diff do i fill it up until it start coming out of the middle plug or just max it out?..never did a diff swap so sorry for the noob questions i searched but just a bunch of different crap came up about lsd...also what kind of transmission fluid would be the best for a sr20 transmission
badbob2121
Car: '92 Nissan 240SXS13 Hatch ELLIS JUAN
'12 Ford Mustang GT RTR
i used 80w90 in my hlsd... if that helps maybe?
costa_rican13
Car: 1993 s13 coupe
i used 80w90 in mine too. for the transmission either AMS OIL or REDLINE, i hear theyre in big competition and ppl will kill to defend theirs beliefs. lol but i used REDLINE MT90 and got rid of my roughness in the third gear. dont use the MTF.
MyNISMO314
is there a link on how the hell to remove the s13 diff?? i took all the bolts out expecting it'll just lower down along with my jack but the axels are still holding it in place...any write ups on this matter?
costa_rican13
Car: 1993 s13 coupe
you have to drop the driveshaft end that connects to the diff. then loosen all of the 6 bolts, make sure to hold the front of the diff since it will fall down. once you have the diff in your support. push the diff and 1 axle up and roll the diff side ways away from the axle and slide the axle end out of the output flange. then keep that axle held up and pull the diff towards that axle. then its out. :) its really a 2 person job because you risk the chance of it falling on your face or damaging the unit itself. your friends will have to help you or someone. be safe!! and GL you can do it. me and my buddy did it. with no jack..
